by Anya Investigator
customer service advised roaming activated on my account but cannot make calls
Solution
Re: customer service advised roaming activated on my account but cannot make cal
Is roaming activated under your phone settings?
You will need to contact CS so if you cannot call then you can try live chat tomorrow after 8am UK time. If you click on the cross next to EE the chat options and status will be shown.
Solution
by Profile closed
Not applicable
Hello @Anya you can check if roaming has been enabled on your account by logging in to your MYEE account online and navigating to MYEE>Manage device:
https://id.ee.co.uk/id/login
Have you restarted the device since landing? If so try a manual network search to see if any other local roaming networks are available. 🙂
Good morning @Anya
Thanks for checking in to community 🙂
I'm just following up on this one to see if the help @Northerner and @Profile closed has given to you has helped to sort things out for you.
Please see our Roaming with EE - What to do if you're having problems abroad post for some further support, if you need it.
Richard
by Skilled Contributor
Skilled Contributor
Hi @Anya,
There is a freephone number for EE Customer Services that you can call free using Skype or another VoIP app, from a computer or your mobile phone via WiFi - it's +44 800 956 6000 .
Other than Skype, Tesco International Calling app is another good option - when you install it on your phone it gives you £1 free credit. 0800 numbers are free from this app as well, and of course it can be used over WiFi.
One of the above options should enable you to ring through to EE over any WiFi connection (hotels, restaurants, etc.), and get your roaming activated.
Thanks for offering some more assistance @DonDino
Hopefully some of the help given will get the customer up and running.
Cheers
Richard
