by Robertsax1
could not activate mobile data network abroad
Hi All
I need desperate help. I’m in Tanzania and i cannot use my roaming, i keep getting the following message  ‘could not activate mobile data network, PDP authentication failure "
I have reset phone, rest network settings, switched on and off roaming and wifi.
Any idea how to solve this?
Re: could not activate mobile data network abroad
Hello @Robertsax1
Thanks for coming here.
Can you receive calls and texts?
Do you get this message when you try and access data?
If you have a pay monthly account can you follow the below steps?
If you log into your My EE account online go to Menu > Manage Device > Roaming and Call Abroad and Premium rate calls > This will show as ticked if this is set up for you, if not can you activate this?
Speak soon.
Leanne 🙂
by Robertsax1
Hi Leanne
i can’t receive or send texts and calls. When i tried to open safari that was the message I received.
That box is ticked already.
Thanks @Robertsax1.
Do you have another UK mobile available with you?
Do you get an error message when you try to make a call?
Jon
