by MarcoDiRaimondo
cannot make phone calls while abroad (EU)
Hi everyone,
I'm abroad right now, in Italy, and I'm unable to make any phone calls, both towards UK and local. I tried calling the support number, but the pre-recorded voice from an italian provider tells me I have a block active.
Can someone investigate the issue?
I tried doing a network search around where I'm not, with no results.
Thanks!
Solution
Re: cannot make phone calls while abroad (EU)
Hi @MarcoDiRaimondo.
Welcome to the community.
I hope you're having a great time in Italy 🙂
Could you log into your My EE Account online, and check that international and premium rate calls are active?
Please also check that roaming is active while you're there 🙂
Jon
Solution
Jon
by MarcoDiRaimondo
Hi there,
I solved the issue using chat from my laptop, because with phone I could do nothing. Now the issue is fixed, seems like roaming for calls was not enabled.
You can mark the issue as solved.
Thanks,
Marco
Hello @MarcoDiRaimondo
Thanks for coming back to us and letting us know 🙂
Hope you have an amazing time in Italy!
