by niamhbennett
can i use my phone in france?
I'm going to Normandy, France tomorrow, would I be able to use my data there without it charging extra?
Solution
Re: can i use my phone in france?
Yes you can. Just txt ROAMING to 150 to ensure roaming is activated on your account.
More information on EE and roaming can be found here.
Solution
by Ace Contributor
HI,
@niamhbennett
Yes you can use your phone in France without any extra cost.
Make sure you activate your roaming before travelling you can do this texting Roaming to 150.
I will suggest you call customer as well to make sure your international call barring removed and roaming activate on your account.
Enjoy your holidays.
Many Thanks
