by emmareeves
can i use my data in the USA
Hello,
Going to the USA for 10 days can I use my data over there like I can in Europe?
Thanks,
Emma
9 REPLIES 9
by Ace Contributor
Re: can i use my data in the USA
Hi @emmareeves
It all depend which tariff you on.
Please click on this link
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/usa
You can get all required information about USA roaming
by emmareeves
I am just on a pay monthly sim only tariff is that a max plan? I am confused by what the ticks mean also!
@emmareeves: Only if you are on an EE Max Plan or you buy the Go Further add-on for £60 over 6 months.
by Ace Contributor
Hi @emmareeves
When did you get your sim contract.
Click here https://myaccount.ee.co.uk/my-plan/?mp_action=action_view_plan_details&contextKey=revwzeor0jh85mkze0...
Login My ee Web account and you can your plan details.
Hi @emmareeves,
Thanks for visiting the EE Community.
Were you able to check which plan you are on following @tahirmian's advice?
by emmareeves
I am still unsure whether i have a max plan.. it is a EE Sim only promo plan 20GB data for 18 months contract
by Ace Contributor
No then this will not be a max plan.
Hi @emmareeves,
What is the name of your plan as displayed in My EE under 'Plan and add-ons'?
The ticks mean "Included" in your tariff.
EE hasn't sold Sim-Only Max plans for ages.
