by markyd
New Member
can i divert mobile after leaving the UK
Help!
Forgot to divert mobile to landline before leaving the UK for holiday.
How can I divert all calls while in Portugal?
by Ace Contributor
Solution
Re: can i divert mobile after leaving the UK
Hi @markyd just set up the divert as usual from the call forwarding menu, it will set the unconditional divert up as it would have done from the UK
Or use the GSM codes.
Divert all
Set: **21*destination#[SEND]
Cancel: ##21#[SEND]
Query: *#21#[SEND]
Any problems, let us know!
by Ace Contributor
Solution
Divert all
Cancel: ##21#[SEND]
Query: *#21#[SEND]
