by attony Investigator
can help check dp15 pack not able use data/calls in Finland
could you help with below:
roaming on / send balance to 150 checked the data pack activated, but cant use data or make a call in Finland.
6 REPLIES 6
Re: can help check dp15 pack not able use data/calls in Finland
Hi @attony,
Welcome to the EE Community.
Have you tried selecting a different network manually?
If you need help with this, just let me know what type of phone you are using.
Yes, iphone 6 / samsung phone s6, connected to Telia FI 4G and got replied from '150' with correct data pack activated, but cant surf the net, cant make any calls.
Hi @attony,
What happens if you try to make a call or browse the web?
Are other networks showing as available?
shown:  Could not activate mobile data network. you are not subscribed to a mobile data service.
what do mean by other network? different carrier? no, just let phone auto serach.
Hi @attony,
Yes, please try to connect to a different carrier manually to see if that helps.
Let me know how you get on.
May i know any specific carrier to select? and currently not able to test, no with this sim card in phone.
could check the status of the number ? i will pm you the number.
