by Nannyb
can a sharer sim share data on europass?
Hi, my granddaughter has a sharer sim on my account, we are going away this summer and i have a 4g ee plan which allows me calls and texts but need to buy a europass for the data ( mainly my granddaughter but i will use it as well) will she be able to use the data as part of the sharer sim or will she need her own europass? thanks for any help.
EE Employee
Solution
Re: can a sharer sim share data on europass?
Hi and welcome to the Community @Nannyb
It may be worth having a look at our post on the new roaming regulations that are coming into effect soon as it may help.
Many thanks,
Lee
EE Employee
Solution
Many thanks,
Lee
