by Louisere Investigator
calls restricted
I'm in Spain, on an EE personal plan but although roaming is set up, I can't make phone calls. Says they're restricted. Can you help please?!
6 REPLIES 6
Re: calls restricted
@Louisere  So you activated roaming on your account before you left the UK ?
Yes. I can text, use wifi and data etc fine. Calls are restricted when I try to phone someone and it tells me to ring 470. I do this and get a message in Spanish
@Louisere   Have you tried restarting the device ?   And have you enabled roaming on the device and what device is it ?
iPhone 6. Phone has been restarted too. Never had a problem before
Sent from my iPhone
Hi @Louisere
Welcome to the EE Community, I hope you're having an amazing time in Spain so far. 🙂
Could you try a manual network search and selecting an alternative network operator?:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if that works.
Chris 🙂
@Louisere   Just to check can you go to Settings>Phone amd make sure  Dial Assist is switched on.
