by nikkijpaterson1 Investigator
calls from International country but it won’t work
I’m tying to make some urgent calls From Bali but can not phone customer  services to make sure my phone is able to do this. Please help!
9 REPLIES 9
Re: calls from International country but it won’t work
@nikkijpaterson1 : If on contract, did you activate roaming on your EE a/c before you left UK?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
I didn’t activate it before I left Uk as didn’t think I’d need to be making calls. My mistake! How do I fix this?!
As I said previously, in your MyEE.
I’ve done that in My EE and everything is switched on and accepted but it still won’t work
Then you'll need to phone EE. Try calling the Freephone no. in my sig over Skype.
I’ve tried that but nobody is answering
Hi @nikkijpaterson1,
Welcome to the EE Community.
Customer Care open at 8am UK time.
Have you been able to get through?
Yes and they said they’ve fixed it but it still isn’t working. They even got me to manually select the network and that won’t work either.
It could be a local network issue.
Have you been able to try using your phone at more than one location?
