by alexfry1
calling the UK from Majorca?
I have an EE Regular 1GB plan. Can I use my calls texts and data allowance when calling from Majorca,Spain or will I incur extra charges?
Solution
Re: calling the UK from Majorca?
@alexfry1   You can use your allowances at no charge just make sure you enable roaming before you go.  Text Roaming to 150 enable it.
Solution
by alexfry1
Many Thanks
EE Employee
Enjoy your time in Majorca @alexfry1
Pop back if you need anything else!
Thanks - Karen. Smiley Happy
by alexfry1
Sent from my Samsung Galaxy smartphone.
