by Eleanorclare Investigator
calling Australia from Germany
In Germany and cant call Australia. Still have 150 mins left. Why is it not working?
Solution
Re: calling Australia from Germany
Hi @Eleanorclare,
You can still call Australia from Germany but it wouldn't be included in your call allowance.
8 REPLIES 8
by Profile closed
Not applicable
Hello @Eleanorclare is roaming enabled on your account? You can check by logging in to MY EE online and navigating to MY EE>Manage device:
https://id.ee.co.uk/id/login
Here is a link containing more information on what to do when you are having problems roaming abroad:
https://community.ee.co.uk/t5/Roaming/Roaming-with-EE-What-to-do-if-you-re-having-problems-abroad/td...
Hi @Eleanorclare,
Welcome to the EE Community.
Are you using a pay as you go or pay monthly plan?
Hi
Thanks for helping.
I am using Pay As You Go and Roaming is switched on.
Eleanor
Sent from my iPhone
Hi @Eleanorclare,
Which pack are you using?
Do you have sufficient credit to make the call?
Hi
Thanks for your help!
I'm using a £10 pack which I thought included 150 mins of calls to included countries. Do I need credit too?
Eleanor
Sent from my iPhone
Sent from my iPhone
Hi @Eleanorclare,
Is it the international SIM?
If it is, you can use your minutes, text and data allowances while you’re travelling in the EU. Calls to the 34 destinations within your pack are only from the UK.
However, calls to any EU country are included within your pack when roaming in the EU.
If you want to call a country outside the EU or you’re travelling to a country outside the EU, you won’t be able to use your pack allowances and will be charged roaming rates during your stay.
For more information on these charges, please check our pay as you go roaming rates.
Hi James
The pack I bought included Australia. Does that mean I can only call Australia from the UK?
Eleanor
Sent from my iPhone
Solution
Hi @Eleanorclare,
