by Evans2
New Member
abroad
my phone is already set up for use abroad but do I have to do anything or will it automatically be ready for use?
Solution
Re: abroad
Hi @Evans2
Further to what @Chris_B has expertly advised, our Max plans also allow you to use your inclusive allowances in USA, Canada, Mexico, Australia and New Zealand.
I would advise texting ROAMING to 150 just to double check everything is set up.
Also, please check out the roaming costs on our roaming tool before you go.
Have an amazing time, wherever you're going. 🙂
Re: abroad
@Evans2  You just need to restart it when you get abroad.   If your going to the EU you can use your data, calls and text from your allowance.  You might also need to switch on data roaming on the device it’s self.
Solution
Re: abroad
Hi @Evans2
