by Stuart003117
Will there be any charges for using my phone in spain
Solution
Re: Will there be any charges for using my phone in spain
@Stuart003117    You can use your allowance in the EU now but you can only use up to 15 GB of data per month if your tariff has more than this
 Just text roaming to 150 to enable roaming on your account.
 Also log into your EE online account and make sure call abroad and premium rate numbers is enabled otherwise you will not be able to come back to UK if need be
Solution
Not if you have any allowances & keep to them. It is part of EU. You may use your allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
