by Duffelean
Will spend 4 nights in New York, what are best options for using a UK mobile
Re: Will spend 4 nights in New York, what are best options for using a UK mobile
Hi @Duffelean
What tariff are you on?
by Duffelean
I am on Pay Monthly
Sent from Outlook
Hi @Duffelean.
Do you know if you're on one of our Max Plans?
A Max Plan will allow you to use your UK allowance while you're in New York, if you aren't on a Max Plan you would need to look at buying a bundle.
Jon
