by Hbeards
Will phone Work fine in Cape Verde ?
by Ace Contributor
Solution
Re: Will phone Work fine in Cape Verde ?
Hi @Hbeards As long as you've enabled roaming, it will work. Text ROAMING to 150 now to check if it's all set up.
You can see the reasonable rates for data and calls here:
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/cape-v...
by Ace Contributor
Solution
It'll work but you'll have to pay to use it, as given in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/cape-v... .
Good Morning @Hbeards.
Welcome to the community 🙂
I can see you've had some great advice already.
Just make sure roaming is enabled before you go, this can be done by text as @chistery has mentioned, or using your My EE Account.
Roaming charges will apply in Cape Verde.
Jon
