by Jameslong545
New Member
Will my phone work in Spain
Going to Spain will my phone work
Solution
Re: Will my phone work in Spain
Hi @Jameslong545
If you are a pay as you go customer, roaming is already active and ready to use.
If you're a pay monthly customer on any plan, you will need to check roaming is set up before you travel.
If you log into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
If they are not ticked, activate both to use your phone in Spain 🙂
You can use your minutes, texts and up to 15GB of data in Spain.
Hope you have a lovely time 🙂
Solution
Hi @Jameslong545
