by Heidi75
Will i need a bolt on for roaming when traveling to Dublin?
Hi all. I am traveling to Dublin in the morning and do not know if i will need to activate roaming or buy a bolt on, can anyone help please?
by Brilliant Contributor
Solution
Re: Will i need a bolt on for roaming when traveling to Dublin?
Hi @Heidi75 You will need to check roaming is activated do this by texting roaming to 150
What plan are you on does it include Eu allowance?
Solution
by Heidi75
Hi and thank you. My current plan covers all EU and UK, this is both text and minutes
@Heidi75 Your welcome have a great time
