by ianslater77 Investigator
Will I be able to roam in any European country if I am using an eSim?
by Brilliant Contributor
Solution
Re: Will I be able to roam in any European country if I am using an eSim?
@ianslater77 , Yes, it does not matter whether it is a physical sim or an ESim, they both work the same, just make sure that you have roaming enabled on your account and premium and international calls enabled.
You can find all the details here:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Getting-ready-to-use-your-phone-abroad/td-p/749932
Be aware that if you are near a border, such as Turkey or in some parts of Cyprus, you may get connected to a network that is not part of Europe, where you would then pay for the calls.
Solution
