by Tomcass171 Investigator
Why won't my phone connect to the Internet within Europe.
My phone is set to roaming at UK and international and my data is turned on.
My phone won't connect to the Internet services in Malta though.
Can anyone help.
Re: Why won't my phone connect to the Internet within Europe.
Have you turned roaming on under network settings?
Yes my roaming is turned on.
That doesn't seem to make a difference.
Hello there @Tomcass171.
What device are you using?
Do you get an error message when you try and connect?
Thanks 🙂
A Sony Xperia z5 compact
And it connects and then doesn't work and it keeps changing.
Thanks for confirming @Tomcass171
Are you able to select a different network and try and connect?
Thanks 🙂
