by Craigrobertson8
Why won't my phone connect to network in Spain
My iPhone6 will not connect to network in Spain. Have tried all fixes but Nothing works, all other suggestions are to contact EE which I obviously cannot do.
Any suggestions or staff help appreciated.
by Craigrobertson8
Re: Help me connect my phone abroad.
Am having the same problem, please help!
EE Employee
Re: Why won't my phone connect to network in Spain
Hi @Craigrobertson8 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
by Craigrobertson8
Hi, I can search for and select other networks but no connection is made. I cannot make the calls as suggested
EE Employee
Hi @Craigroberson8
Are you able to recieve calls/texts?
Many thanks,
Lee
