by Bigmedic999 Contributor
Why isn’t phone working in Europe .. the app says allow use abroad ?
  1.
Solution
Re: Why isn’t phone working in Europe .. the app says allow use abroad ?
Hi @Bigmedic999
It may be worth asking her to search manually for a network.
What kind of phone is it?
12 REPLIES 12
@Bigmedic999 : If on contract, did you activate roaming on your EE a/c before you left UK?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Hi
my friend has the phone interior but it’s in my account and I control the app....I didn’t know she was going abroad and she was already there when she messaged me her phone wasn’t working ... I turned the roaming on here in the uk but her phone still isn’t working in Europe ? Any ideas ?
It could take up to 24 hours to activate or you can call EE.
Hi , thanks ...its been over 24hrs now but will call EE in morning ....
do you know if I activate here in the uk on my app that her phone in Europe will activate for roaming ?
thanks for your help
Andy
Yes, what you do in MyEE will be applied to the phone wherever it is.
It hasn't been 24 hours since you activated Roaming in MyEE, has it?
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
Thank you for your help
i wilk call ee in morning just to make sure it is activated as she still says it doesn’t work ... she is using WiFi to WhatsApp me ...
Thanks again
by Profile closed
Not applicable
@Bigmedic999 what do you mean by "my friend has the phone interior"?
it was a typo error ...
by Profile closed
Not applicable
@Bigmedic999 so what was it meant to be?
OP, the phone's owner ,is in UK. Friend is using phone in Spain.
by Profile closed
Not applicable
@Bigmedic999 and @XRaySpeX well now that's cleared up, don't forget that the phone itself will also have its own Roaming setting which must be on, too, in addition to the My EE Settings that @XRaySpeX has already mentioned. On my phone it's in Settings, Network, Mobile Settings, Roaming.
Solution
Hi @Bigmedic999
