Highlighted
Why have I been charged every day after texting TRAVEL. I only used data one day
Highlighted
by Profile closed
Not applicable
Solution
Re: Why have I been charged every day after texting TRAVEL. I only used data one
The Travel pass is automatic and will renew every day at midnight UK time whilst you are abroad unless you stop it manually or turn off your data roaming via your handset settings.
More details can be found here.
Highlighted
by Profile closed
Not applicable
Solution
Highlighted
Good Morning @brj16
Did you turn data off on your phone settings?
The Travel Data Pass daily charge will automatically trigger each day you use mobile data on your phone when you're abroad.
Your phone will use data if you have apps that automatically update in the background. This will trigger the daily charge.
Speak soon, Leanne 🙂
Highlighted
I did turn data off and hadn't used it except for that first day
Highlighted
EE Employee
Hi @brj16 and welcome to the comunity.
I have sent you a private message on here, so I can get some details from you.
Thanks,
Lee
Recent solutions
