by Sjames18
Why does my phone not pick up a service abroad?
Re: Why does my phone not pick up a service abroad?
Hi @Sjames18
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Hi @Sjames18
Welcome to the community. 🙂
Whereabouts in the world are you?
If you're still having problems after following @Northerner's advice, I recommend trying a manual network search.
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let us know how you're getting on.
