by Stephenee
Why can't I watch Netflix while roaming (EU)?
In the Netherlands on a 4GEE Max plan (loads of data). Netflix returns error code 10013.
Tried VPN, still doesn't work. Is streaming banned while roaming? Wasn't made aware of this when joining recently.
Re: Why can't I watch Netflix while roaming (EU)?
@Stephenee  It might be a Netflix issue and your android device as you can watch over a roaming network,
have a a look at THIS
by Stephenee
Thanks for the response! Haven't been able to test it yet, but it turns out there was a problem with Netflix.
