by Bshiels83 Investigator
Why can't I use my call plan in the USA when I was advised I could on ee Max ?
I have an ee Max plan and have been advised that all I have to do is switch to a local network and I'm ready to go. Yet I've landed into Orlando and can't use my plan!!
6 REPLIES 6
Re: Why can't I use my call plan in the USA when I was advised I could on ee Max
Did you take out your EE Max Plan after 10 May 2017?
@Bshiels83? Did you enable roaming on your account before you left the UK ?
Yeah I called them beforehand and they said I was fine to go but it doesn't work. It's a Max plan and was advised USA mecixo and some other countries included but yet it won't let me call home. I was with three before and never had any issues
I took it out 2 weeks ago before the plan changed. The Max plan then included USA mecixo and some other countries too on top of eu
by Ace Contributor
@Bshiels83 If you took it out a few weeks before 10th May, it won't include USA, and you would have to add the travel data pass for the USA. Other data-ons are available too
Are you able to connect to ATT or T-Mobile, and reach http://add-on.ee.co.uk/ ? This would show that roaming is working at least.
If you can't call home though it suggests you still have a bar on your account.
Hello there @Bshiels83
Can you receive calls and texts?
Do any other networks work for you?
Speak soon, Leanne.
