by Leanne93 Investigator
Why can’t I text or call from France? I received the text saying It’s included
It is included in my allowance but it will not let me use text or call out
Re: Why can’t I text or call from France? I received the text saying It’s includ
@Leanne93  Did you enable roaming on your account before you left the UK ?
Are yiu putting 44 or +44 instead of the 0 at the start of the number?
have you tried restarting the device since you got there ?
I didn’t enable as I was told just to put roaming on when I got here but that doesn’t work
ive tried putting the correct numbers in front and turning phone on/off
@Leanne93  Login to your EE online account and wait for a live chat window pop up you can use this to chat to customer services to request roaming to be enabled on your account.
Thank you will try that
EE Employee
Hi @Leanne93 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
