by Mbannon Contributor
Why can't I send texts abroad?
Solution
Re: Why can't I send texts abroad?
@Chris_B: I know but OP is posting under Roaming & I generally believe peeps know what they are doing until proved otherwise. OP has just confirmed I read it correctly.
Also you asked where I was, not OP Smiley Wink
12 REPLIES 12
Can you make & receive calls abroad?
@XRaySpeX   When you say abroad are you abroad right now ? Or are you trying to text a UK number or a  foreign number ?
If it's a foreign number you need. To call customer services and request that international and premium rate numbers are enabled on your account.
@Chris_B: I presume I'm in the same country as you are Smiley Wink, but the OP is abroad.
I'm in France. I can receive texts but not send any.
@XRaySpeX   Reading the title it just says
"why can't I send texts abroad".
Does that mean they are abroad or trying to send a text abroad?
You've not got enough information to actually answer the question correctly.
@Mbannon  Did you call customer services to request that roaming be enabled on your account.
No. Didn't realise it was required. Can't make calls either
Solution
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Thanks for the help 😊
Yep, was able to activate it through online account. Took about an hour to activate.
Thanks for the help
Well done :)! Glad I could be of assistance.
