by Borgvinator
Why can’t I make it receive calls from Ireland
Hi can anyone tell me why I can’t make or  receive calls from Ireland as I’ve been to Portugal with the same phone network and package and it worked fine
EE Employee
Re: Why can’t I make it receive calls from Ireland
Hi @Borgvinator and welcome to the community.
This is very strange indeed.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
