by Guy77 Investigator
Why can't I make calls and send texts from West Africa?
EE say that they are going to cancel my number. I am currently in West Africa but can't make calls or send texts from my EE number. I have a pay as you go sim with credit. I stopped off at an EE shop before coming and they said it would work fine. It doesn't!  I will still be here 5 more months volunteering for a charity. What do I do?
Re: Why can't I make calls and send texts from West Africa?
@Guy77  You are putting the correct country code instead of the 0 at the start of the number?   Have you tried turning off 4G ?  Have you manually search and selected a different network?
Good Morning @Guy77.
Could you try @Chris_B's suggestions and let us know how you get on?
Have you been able to make any calls or texts since you got there?
Do you have a signal?
Jon
