by Erinkatypearce1
Why can’t I call or text the UK when travelling Europe? (I can recieve calls)
I pay monthly and get a text in every country telling me I can use my plan as normal but still can’t call or text the UK. Roaming is on.
by Erinkatypearce1
Re: Why can’t I call or text the UK when travelling Europe? (I can recieve calls
There was only one other carrier option and when I clicked on this I had no service. I am going to Prague tomorrow so can try then.
Sent from my iPhone
EE Employee
Hi @Erinkatypearce1 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee​​​​​​​
