by Harrietem
New Member
Why can i not send texts in the eu when i can receive them using my 4GEE plan
I have a 4GEE plan and can receive texts and use data but cannot send texts or make calls. I cannot remove the international call barring as it says the password is rejected. Is this an issue with my plan or phone?
EE Employee
Re: Why can i not send texts in the eu when i can receive them using my 4GEE pla
Hi and welcome to the Community @Harrietem
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and ring using format of 00447*********
Please may I know which country you are in?
Many thanks,
Lee​​​​​​​
