Highlighted
by Investigator
Why can I not make calls / text in feuteventura. Roaming activated correctly?
Hi all, in fuerteventura.
4G working.
roaming enabled.
switched on & off, still can’t make calls or text.
Only call I can make is to 470, which says something in spainish then hangs up, and help would be great fully received
9 REPLIES 9
Highlighted
by Investigator
Re: Why can I not make calls / text in feuteventura. Roaming activated correctly
Using auto country code.
But also tried manual country code.
Same orange advice comes on.
Orange full strength, with 4g also.
Sent with awesomeness
Highlighted
by Investigator
pay monthly.
Not received a call or text, so far.
I am using iPhone 6, with auto country code.
I have also done manually with no succcess.
Highlighted
Hi @AJFI,
Welcome to the EE Community.
Hope you are having a great time in Fuerteventura. Smiley Happy
Are you able to receive calls?
What happens when you try to make a call?
Are you using a pay as you go or pay monthly plan?
Highlighted
by Contributor
Have you checked to make sure that when you're calling and texting you're using the corret country code before you do this?
And what network is showing in the corner of the phone?
Sarah
Highlighted
by Investigator
Hi James,
please see response above;
but in summary
ehen making call I am advised to contact 470, by orange as phone calls to number(s) I try are barred!
Highlighted
by Investigator
Hi Sarah,
using auto code on iPhone & also attempted manual.
it shows full bars; orange; 4g
Highlighted
Hello there @AJFI
Thanks for coming back to us.
Can you receive calls?
Are you with us on a pay monthly personal account?
Speak soon, Leanne 🙂
Highlighted
by Investigator
No calls received
ee personal pay monthly account
Highlighted
Hi @AJFI
Thanks for coming back to me.
In this case, I recommend logging into your My EE account on your phone's browser (not the app) or a computer.
Once you're logged in, a chat window will pop up when an advisor is available.
They will be able to get this looked into for you.
