by Mje1
Why are my Calls back to The UK Barred I'm in Hungary
Solution
Re: Why are my Calls back to The UK Barred I'm in Hungary
@Mje1 : If on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't & can't do the above.
Solution
Hi there @Mje1
Thanks for coming to the community 🙂
Has the advice from @XRaySpeX helped you make calls in Hungary?
Let us know how you are getting on 🙂
