by liz59
Why am I unable to make calls in Vietnam
Re: Why am I unable to make calls in Vietnam
@liz59: Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Can you go on the Net & send texts?
by liz59
Thank you, yes you’re correct I didn’t activate anything before leaving. I never have before so just assumed.....:(
I can’t call any numbers, including landlines. What is my sig?
Sent from my iPad
My signature is the bit at the bottom of my post. Can you see it? It has EE's phone nos in it. You can try calling them over Skype.
Have you looked in your MyEE Manage Device?
