by barbara21a
New Member
Why am I unable to call or text from Portugal, but can receiving incoming calls
I have recently arrived in Portugal and tried to text and phone home, but get a message that I am not permitted to call that number (at least I think that’s what it says as it’s In Portuguese). I can receive incoming calls, and I can’t see anything obviously wrong with my phone settings
EE Employee
Solution
Re: Why am I unable to call or text from Portugal, but can receiving incoming ca
Hi @barbara21a and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee​​​​​​​
EE Employee
Solution
Did this work?
Many thanks,
Lee​​​​​​​
