by JanisT
Why am I being charged for use on travel add on when I didn’t switch it on?
10 REPLIES 10
Re: Why am I being charged for use on travel add on when I didn’t switch it on?
@JanisT  The moment you get to another country and start using data it will start.   You might of received an email and that’s enough to start the add on.
by JanisT
But I’ve only accessed data using Wi-fi - not general roaming - so am puzzled. Shouldn’t have activated on that basis?
Sent from my iPhone
Morning @JanisT
Welcome to the community.
Do you have data turned off in your settings?
Also, what phone are you using?
Speak soon, Leanne 🙂
by JanisT
Hi Leanne
Yes, data switched off before departure from Uk. I have an I-phone 7.
Regards
Janis
Sent from my iPhone
Hi @JanisT
Thanks for coming back to me.
Do you have WiFi assist turned on in your settings?
Go to Settings > Mobile Data > WiFi Assist.
Thanks, Leanne.
by JanisT
Hello again
No, it’s off.
J
Sent from my iPhone
Thanks for checking @JanisT
We will need to get this looked into for you.
If you get in touch with us we will be able to check your account.
Let me know how you get on.
Hope you have an amazing time 🙂
by JanisT
Thanks Leanne. Will do so when back at home base. Appreciate your responses in meantime.
Kind regards
Janis
Sent from my iPhone
by Ace Contributor
If you know you won't need data, you could remove the add on from the app?
by JanisT
Thanks for this, and that was the first thing I did when I saw the charges, although for some reason it takes a month for it to go. Just hope I’m not getting charged for something I’m not using!
Sent from my iPhone
