by Vytautas
Why I can't use the mobile data in the EU? It's not working in EU.
Re: Why I can't use the mobile data in the EU? It's not working in EU.
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
by Vytautas
Yes, I activated roaming on my EE. In a country like a France or Poland I
have a mobile data. All problems started when I arrive to Lithuania. Why?
by Ace Contributor
@Vytautas, try turning 4G off and doing a manual network search.
Hi @Vytautas,
Welcome to the EE Community.
Have you been able to connect after following @chistery's advice?
