by Gryndzia86 Investigator
Why I can't call from Poland
Hi, I have problem with the international calls. I'm in Poland and can't make any calls even to UK . What I need to do??
by Profile closed
Not applicable
Solution
Re: Why I can't call from Poland
Hello @Gryndzia86 has roaming been enabled on your account? You can check by logging in to MY EE online and navigating to MY EE>Manage device:
https://id.ee.co.uk/id/login
Here is a link containing more information on setting up and using your phone abroad:
https://community.ee.co.uk/t5/Roaming/EE-roaming-Getting-ready-to-use-your-phone-abroad/td-p/532570
by Profile closed
Not applicable
Solution
Hi @Gryndzia86
Thanks for coming to see us in community 🙂
Just checking in to see if the great advice @Profile closed has given to you has helped get you active?
Richard
thank you.
Sent from my iPhone
by Profile closed
Not applicable
You are welcome @Gryndzia86 enjoy the rest of your time away and come back to the community anytime if there is anything else you would like to know. 🙂
