by Abs79
New Member
Which countries can I use my data plan in?
by Brilliant Contributor
Solution
Re: Which countries can I use my data plan in?
Hello @Abs79 ,
Welcome to the community,
You can use your data plan put to 15GB in Europe, I would also suggest taking a look here to make sure that you are all set up before doing so:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Getting-ready-to-use-your-phone-abroad/td-p/749932
Solution
Hello @Abs79 ,
Recent solutions
