by joeaj
Which Canadian network do EE piggy back on when using data in Canada?
No one at EE who I spoke with seemed to know, it seems to be very difficult to find this information. Is it Rogers, as I have seen that mentioned on a couple of websites but nothing official?
13 REPLIES 13
by Profile closed
Not applicable
Re: Which Canadian network do EE piggy back on when using data in Canada?
Well, according to this page, EE do use Rogers in Canada for 4G (expand the 'Using 4G abroad' section).
No idea if they use any other networks for just 2G or 3G though sorry?
by Brilliant Contributor
It was Rogers as suggested by @Profile closed
Also when I was there I did briefly see Bell on my phone.
This was 3 years ago though.
by joeaj
Thank you both!
EE Employee
Hi @joeaj
Just to confirm both Rogers and Bell are available to use whilst Roaming in Canada.
Thanks - Karen. Smiley Happy
by Ennis-obrien
To Karen at Community Support
Can I confirm that my phone will work on the Bell network? This is important as there are parts of Newfoundland where Rogers simply has no coverage, but Bell has.
Many thanks.
EE Employee
Hi @Ennis-obrien and welcome to the community.
You would need to perform a manual network search to give you the ability to select the preferred network of your choosing.
As @Karen_C has mentioned both Bell and Rogers are available.
Many thanks,
Lee
by Ennis-obrien
Many thanks for your help.
EE Employee
by thewhitelion27
I can comprehensively confirm that EE contractual obligations are overseen by Rodgers. Rodgers is one of the 3 main providers in Canada. The main advantage of this contract is that Rodgers have an ongoing agreement with the other main providers TELLUS and BELL where if Rodgers are unable to provide connectivity then it automatically takes on one of the other two if available.
This is the case across all of Canada as I have just witnessed and checked personally.
You can not set your phone to default to the others however. It will change automatically when there is a alternative signal available.
I can also further state that with the older 2017 max plan that if you  have more than 15GB of data in your plan you will be able to use all of it at no additional cost. With the new 2018 max plans however, you will be capped at 15GB.
Hope this helps. 😉
Where is that documented & confirmed by EE?
by thewhitelion27
I have no idea but it's what at least 5 advisors have said to me. They
seemed absolutely sure so it must be written some where.
@thewhitelion27: But it isn't written anywhere. Only the EU has a 15 GB / month Fair Usage limit written everywhere.
Ask 4 EE agents & 2 will say it is & 2 will say it isn't is other users' experience.
@thewhitelion27  “Hope this helps” you were talking to somebody who asked the question back in 2017. Your a little late with the help.   Lol.
