by katiecarr96
New Member
When using the EE max plan in Australia is there a strong signal connection?
I am moving to Australia and wondering if the Max Plan signal is strong while being over there?
Re: When using the EE max plan in Australia is there a strong signal connection?
Hi @katiecarr96
Welcome to the community. 🙂
When roaming in Australia, your phone will be able to connect to a number of different Australian networks to ensure that you have a strong connection.
I'm not sure if you're aware of this, but, I feel it is necessary to advise you of our stable links policy:-
EE plans are intended for customers with a stable link to the UK who travel abroad periodically. They are not intended for customers roaming on a permanent or semi-permanent basis. We will consider you have a stable link to the UK if spend a total of 60 days or more during any 120 day period within the UK. If your usage abroad in the EU/EEA exceeds this, you will be alerted by text, and after a 2-week period we may charge you for services you use or block your SIM card and roaming services. We’ll let you know before we do anything.
Find more information on stable links >
Good luck in your new venture. 🙂
