by Yorkie71
When I travel to the USA next week, if I use data will I be charged extra?
Solution
Re: When I travel to the USA next week, if I use data will I be charged extra?
Hello @Yorkie71
Welcome to the community.
If you're on a pay monthly Max plan started after 10 May 2017, or Roam Further Swappable, you can use your calls and texts, as well as up to 15GB of your data allowance.
For any other plans, you can check out our available add-ons and prices on our roaming tool.
Make sure your roaming is set up before you go too. You can do this in your My EE account or by texting ROAMING to 150.
Have a great time 🙂
Leanne 🙂
Hi @Yorkie71
What plan do you have?
If you have a swappable plan then use the Roam Further Pass. Or subscribe to this service. If you still have a Max plan from 10/05/17 then you can roam as at home.
Solution
Hello @Yorkie71
Have a great time 🙂
Leanne 🙂
