by Gryndzia86 Investigator
What to do when I can't make call from abroad to UK?
EE Employee
Re: What to do when I can't make call from abroad to UK?
Hi @Gryndzia86 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Which country are you in?
Many thanks,
Lee
