by balanpr
New Member
What is the difference between global roaming text/mins and from anywhere text/m
What is the difference between global roaming text/mins and from anywhere text/mins?
Re: What is the difference between global roaming text/mins and from anywhere te
@balanpr   One is for when you are roaming ( not in the UK ). The other allows you to call when in the UK.
@Chris_B : The "From Anywhere" add-ons are roaming add-ons for making calls or texts from wherever you are. As in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/south-... .
There is a "Calling Abroad" add-on for calling from UK.
by Skilled Contributor
Skilled Contributor
In my experience asking this question from EE support staff and using both, they are the same thing. Not sure if that's changed since I last used global roaming and from-anywhere minutes about a year and a half ago.
