by Ethgeddes Contributor
What has happened to the list of country’s with 4g roaming?
What has happened to the list of country’s with 4g roaming I can’t find it anywhere on the website and I used to be able to check which network had it. Also is there an option where I can find which network EE use in each country like three has the option of searching for a country and it tells you what network you can use.
Solution
Re: What has happened to the list of country’s with 4g roaming?
Have a look at Countries with EE roaming agreements . You'll see which ones have 4G ticked.
7 REPLIES 7
Depending on your handset and carrier (EE, Tmobile 2G/3G or Orange 2G/3G) then 4G will be available in most countries around the world. The same applies to network carriers, EE have agreements with most carriers around the world. If you set your phone network to automatic it will connect automatically.
Lists are redundant.
Solution
by Ace Contributor
Well I'm old fashioned and do miss the list. It was nice to be able to see which networks I should be connecting to for 4G when I'm in a particular country.
EE Employee
Hi @Ethgeddes and welcome to the community.
Brilliant find but I'm not to sure if that is for business customers only or if it also is relevant to consumer customers.
I have asked the roaming team for clarification please do pop back here for any updates. 🙂
Many thanks,
Lee
I find it unlikely that Business EE would have diff roaming agreements than Consumer EE. It's just that Business EE is more open with it.
@Lee_H: P.S. It was my find for him.
EE Employee
