by Sidra Investigator
What does the Extended Roaming add-on cover?
Hi
In my account add-ons, there is one roaming add-on option called Extended Roaming which costs £10/month but had no description when you click the “Learn More” button.  Please could someone explain what Extended Roaming gives you and what regions it covers, whether there is a minimum term and whether it can be added if already abroad?
Thanks.
by Profile closed
Not applicable
Re: What does the Extended Roaming add-on cover?
@Sidra More details about that add-on can be found here.
It covers the USA, Australia, New Zealand, Mexico and Canada.  It comes with a 6 month minimum term as well.
There's no reason why it cannot be added whilst you are currently roaming though.
Thanks for your quick response.  Sorry to be a pain, but so you are saying that the “Extended Roaming” add-on listed in the account view is the same as the “Go Further” add-on, and I could buy this by buying the “Extended Roaming” add-on from my account view?
Welcome to the community, @Sidra. 🙂
Sounds like that's the one that it's referring to.
How often do you travel to the extended countries?
Thanks.  I usually spend a couple of weeks a year in either Canada, USA or Australia although it’s going to be a close call to see whether the Go Further add-on for 6months minimum would be worth it for a single trip.
OK, thanks @Sidra
There are other options.
You can find details of costs and available add-ons for each country on our handy roaming tool.
