by JacquieR Investigator
What do I have to do to use my mobile in USA
Hi - is there anything I need to do to ensure my mobile works in Denver?
by Brilliant Contributor
Re: What do I have to do to use my mobile in USA
Make sure roaming is active on your account.
Make sure you purchase a roaming add on so it doesn't cost you the earth.
@JacquieR: Text ROAMING to 150 before you leave.
by Profile closed
Not applicable
Whilst you still have to make sure roaming is enabled on your account before you leave, if you are on EE Max plan (purchased on or after May 10th 2017), all roaming in the US will be included in your standard allowances.
Hi @JacquieR
Welcome to the community. 🙂
I see you have been offered some fantastic help here already.
Check out our Getting ready to use your phone abroad support article.
Have an amazing time in Denver. 🙂
Thanks Chris
Thanks most helpful. And yes we're looking forward to our trip to Denver.
Best regards
Jacquie
