by curiouscaller
What dial tone will my UK caller hear if I'm abroad in Italy?
As the Subject says...if I'm in Italy what dial tone will somone calling from the UK hear? Im guessing it will be an international tone that sounds different?
9 REPLIES 9
by curiouscaller
by Ace Contributor
Re: if I'm in Italy what dial tone will somone calling from the UK hear?
@curiouscallerI assume you mean ringing tone? Then yes, they will hear the more European sound when calling you.
Their dialling tone remains the same as that is generated locally.
by curiouscaller
oh, is it called ringing tone? You know, so they dial me and it starts to ring...but will it sounds like the regular ringing noise or will it sound different?
Thanks for your help!
by Ace Contributor
They are likely to hear a different ring, and know you are not in the UK.
I've had callers know I'm abroad from it, and some haven't noticed.
EE Employee
Hi @curiouscaller and welcome to the community.
Please see the wonderful information above to help you with your query 🙂
Many thanks,
Lee
by curiouscaller
Ok so I'm going to level with you... a Girl has told me shes abroad, but when I call her it rings normally...so she isn't abroad is she? Just want to be certain before I sound like I've gone mad lol
EE Employee
Hi @curiouscaller,
Unfortunately, this is something I would be unable to assist with further.
Many thanks,
Lee
by curiouscaller
I got too personal... my bad Man LOL thanks anyway
by Ace Contributor
Oh, well I was interested, just too polite to ask Robot LOL
There are always going to be exceptions, E.g calls may be routed thorugh a different path that gives the UK ringing tone, so I wouldn't go just on that, just in case!
