by Andrea40 Investigator
What countries out of the EU can l use my minutes and text.
What countries can you use your allowance, but not in the EU ....Thank you
Solution
Re: What countries out of the EU can l use my minutes and text.
If you are on a recent EE Max plan only, USA, Canada, Oz, NZ & Mexico are included in your allowances.
10 REPLIES 10
Hi @Andrea40,
Welcome to the EE Community.
Which plan are you using?
Solution
My plan is 4GB
Unlimited minutes and texting which can be used in EU and other countries.
Comes under their packages £24.99 if l remember rightly.
Thank you James
Thank you XraySpeX
Hi @Andrea40,
Is it a Max plan?
When did you start your plan?
Hi James
I just checked yes it is Max plan.
Andrea40
Get Outlook for Android
Hi @Andrea40
Thanks for coming back to us
When did you start the Max plan?
Thanks 🙂
16th June this year.
Yes, roaming in USA, Canada, Oz, NZ & Mexico are included in your allowances on your EE Max Plan.
Remember that your data allowance is limited to 15 GB / month (Fair Usage Policy) while in those countries or EU.
Thanks for helping @XRaySpeX
For full information see our 4GEE Max Plan information here.
Hope this helps @Andrea40
Thanks, Leanne 🙂
